Old 04-29-2011, 08:39 AM   #7
laphan
laphan's Avatar
Originally Posted by DFW02S
Tip of the hat to laphan for a good call!
Then 5 days later the AOS goes at the track.
Good times with the Boxster!
Sorry to hear that. But if the leak is not that bad, just keep on eye on the trans oil level and fix it later when you need to have clutch, RMS, IMS work (trans need to be removed).
I replaced my AOS even when it still worked early this year. Next is water pump
laphan is offline   Reply With Quote
