Old 02-06-2011, 09:26 PM   #1
Boxster Tie Rod
Hi, I did a search and couldnt really find any DIY info on replacing the Tie rod on the Boxster.
I think I am going to just replace the outer tie rods, car only has 60k
Anyone ever done it?
How hard is it? 1-10 scale
any special tools needed?
dirkdiggler is offline   Reply With Quote
Old 02-06-2011, 10:08 PM   #2
Not hard at all, in fact super easy.
http://www.martinlansky.com/Coppermi...01/W_humps.jpg
'03 Midnight Blue
18" Chromes//Drilled and slotted rotors//pedal upgrade//Alum. Door sills//KSPORT Coilovers//Short Shifter/Strut braces/Clear sides/Hard Top/Speedster humps/Intake//Leather GT3 seats/REVO chip with SPS2
'04 CLK55 AMG 367HP!
'86 944 Guards Red & MINT!
'69 911 Black
PCA Member -Northern Ohio
Cancer Survivor
der Geist is offline   Reply With Quote
Old 02-06-2011, 10:10 PM   #3
Yeah, I actually just watched some Youtube vids and it looks super easy.
Is a alignment always required?
Old 02-07-2011, 05:40 AM   #4
jcb986's Avatar
The tie rods control your toe end...keeps the wheels going straight...if it pulls left or right your toe is out. If the old ends on your car are not really worn, you can adjust the new ones to match the old ones. But, since this is a Porsche you need to have a them reset to specs.
Old Hippie Young Heart
Old 02-07-2011, 12:13 PM   #5
J Tinsby's Avatar
Not a hard job
How hard is it? 1-10 scale =1 or 2
You will need to get an alignment done to check the TOE IN or TOE OUT of the front wheels. You can try and put the new ends on the same amount of turns as the old ones, that will allow you to drive the car to a front end shop where the toe can be correctly adjusted and set.
Negative toe, or toe out, is the front of the wheel pointing away from the centreline of the vehicle conversely:Positive toe, or toe in, is the front of the wheel pointing in towards the centreline of the vehicle.
hth
"Never force it.... get a BIGGER hammer!"
J Tinsby is offline   Reply With Quote
Old 02-08-2011, 08:45 PM   #6
Autobahn Glanz
WhipE350's Avatar
I have not done mine, but this doesn't look too bad http://www.pelicanparts.com/techarticles/Boxster_Tech/59-SUSPEN-Suspen_Overhaul/59-SUSPEN-Suspen_Overhaul.htm
