Old 01-05-2011, 09:18 PM   #1
How to remove switches?
Hi guys,
want to know how to remove the switches around the radio/HVAC area (the ones such as door lock, top operation, T/C, etc.) I can take the plastic wings off that hold them, but then I want to take the switches out of that trim.
Looks like the clip in somehow, thought I might ask before possibly breaking one while I try to pry the wrong spot! Any help?
Regards,
Sam
sparker is offline   Reply With Quote
Old 01-06-2011, 06:04 AM   #2
Simply remove the "horseshoe" trim and the switches just snap in/out, if I remember correctly; I don't recall any trick to removing them
JGM
2002 Boxster S
1973 911 Green FrankenMeanie
PCA DE Instructor circa '95
Old 01-06-2011, 11:07 AM   #3
You may have trouble removing the cig lighter. If you do, let me know and I will walk you thru.
Norminhouston is offline   Reply With Quote
Old 01-06-2011, 01:52 PM   #4
I have removed the horseshoe, but they aren't just 'popping out'. They appear to clip in somehow. I dont really just want to push harder in case I break something.
Can someone who has done this before confirm you do just push harder or if there is a spot you have to press/lift etc?
Sam
Old 01-06-2011, 06:36 PM   #5
Autobahn Glanz
WhipE350's Avatar
If they are anything like the window switches in the center console they are a bit tricky to snap out, study them closely and you'll get them out,I just recently did mine but I can't remember the details to how the switch came out, like all these things once you do get one out it will be obvious lol...like a lot of the panels and such it seems they will break but they do pop out.
Old 01-08-2011, 08:20 PM   #6
Thanks guys - all sorted (including cig lighter) Have my new carbon surround all in place now
Sam
Old 01-09-2011, 08:49 AM   #7
Sam
Let's see some pictures!!
Highlow is offline   Reply With Quote
Old 01-09-2011, 02:17 PM   #8
Ok can do! In picture is the radio surround, my home made carbon iPhone holder, carbon shifter and you can just see the carbon cluster surround.
Turned out well!
Sam
