Old 11-18-2010, 02:15 PM   #1
Steve Tinker's Avatar
Looks something like soft gasket material, at least there are no metal specks, but.....
If it was me, the next step would be to remove the sump (oil pan) and inspect the debris laying in the bottom. Not a difficult job +/- 16/18 bolts.
2001 MV Agusta F4.
Old 11-18-2010, 03:08 PM   #2
Ok, I will do it tomorrow, but do you know if the sump has got gasket, and if it need to be replaced once is open?. thanks
heiwaz is offline   Reply With Quote
Old 11-18-2010, 03:32 PM   #3
Your IMS bearing may not look bad from under the cover but the inside seal could have failed allowing oil to wash out the grease in the bearing. Was there any kind of oil leaking from the bearing?
2000 New Beetle / in search of 03 986S triple black
Caractere kit seam sealed, Caractere rear wing, 1 3/4" drop on coilovers, 235/40/18 Kuhmo XS on 18x8 Millie Miglia Spider II's, H2sport spindles, H&R front Sway bar, O-bar rear torsion, VF Eng. motor mounts, G60 12# flywheel, Nuespeed P-flow intake, Forge DV, Samco IP, Custom K04 turbo and Upsolute chip, 4 bar fpr, TT 2 1/2" SS DP, 2 1/2" custom stainless exhaust no muffler, Peleguin LSD, B&M SS, Momo 14" wheel, R32 steering rack.
yelojkt is offline   Reply With Quote
Old 11-18-2010, 04:00 PM   #4
I have removed the IMS bearing to install the LNE, and the old bearing was in good condition.
Old 11-20-2010, 05:10 AM   #5
I've removed the oil sump and the only things I found is the same gasket particles. This particles came from the sump gasket.
Otherwise, I discovered that one chain tensioner is harder than the other when you push it. I start a new post whith this issue:
http://986forum.com/forums/showthread.php?t=26941
Old 11-20-2010, 09:21 AM   #6
I think, finally find the problem of the buzzing noise.
I removed the spark plugs, and found in the spark tube (1) ans stranger particle non metallic, I hit with a hammer and it broke in 3 pieces. I believe is a little stone and it done a vibration doing the noise. Do you think is it possible?
In this spark tube had an oil leak inside, too.
