Old 07-21-2010, 07:36 AM   #1
kpm
Painted bumperettes
I'm going to paint the rear bumperettes on my 01 S. My question is to the folks that have done this already.
They are slightly textured, so did you paint over the texture or did you make them smooth first,(i.e. sanding them smooth or applying a filler then sanding smooth)
Thanks in advance !!
kpm is offline   Reply With Quote
Old 07-21-2010, 09:38 AM   #2
Sand as smooth as possible.
-Cesar
03' 986 Midnight Blue Metallic
_____________________________________________
Gemballa Lowering Springs | 18” Carrera Light Wheels | Painted Calipers
14/18 H&R Spacers | Aero Wing & Rockers | Powder Coated Exhaust
Creator of CRIOS exhaust mod | De-Snorkeled | De-Ambered
Light Weight Flywheel | Tinted Windows and Windscreen
Painted Bumperettes | 550 Spyder Grille Kit
http://lh5.ggpht.com/_9sTq_sN1KDw/Si...2009%20055.jpg
crios is offline   Reply With Quote
Old 07-21-2010, 10:27 AM   #3
diy thread?
Is there a DIY thread for painting the bumperettes?
Anyone have any recommendations on what kind of primer to use on the plastic before applying paint?
Do you clear coat after painting?
Any suppliers of paint recommendations?
2001 Seal Grey, 2.7L
drem914 is offline   Reply With Quote
Old 07-21-2010, 11:11 AM   #4
Allen K. Littlefield's Avatar
I didn't sand mine and they look fine, you have to get up close to see the texture and it doesn't bother me. The ones that now come painted on P cars are smooth so the choice is yours. You can sand them down as suggested. I had a pro paint mine and the color match is good.
AKL
Old 07-21-2010, 12:29 PM   #5
The problem with using a filler is that they are rubber & the filler is prone to cracking off.
I sanded them smooth, then laid down a couple coats of flexible primer followed by color & clearcoat from www.paintscratch.com.
98 Arena Red 986
Stroked & Blown is online now   Reply With Quote
Old 07-21-2010, 01:03 PM   #6
kpm
Thanks for the responses guys. Just a FYI, I manage an auto body supply store. There are flexible products made for bumpers like Evercoat 411. It's a flexible polyester glazing putty.
I can put a thin coat on, then sand smooth, prime with a urethane primer, sand again then paint and clear.
I'll be shooting BASF Diamont base and using whatever clear I have left from my last job.
Then I'll start on the nose and fill in the license plate holes and repaint up front.
I've already done a little touch up around the left tail light and the color match with the Diamont is spot on.
Thanks again, and if I can answer any questions you might have about paint, feel free to PM me.
Old 07-21-2010, 01:15 PM   #7
kpm
First thing is a soap and water wash, followed by a solvent wipe (pre-kleeno).
I don't recommend spray can primer unless it's also an adhesion promoter, like Bulldog.
Yes, clear coat for sure.
Any paint supplier will work, just make sure they have a system that can check for variations on your color.
Some Honda colors now have up to 18 different formulas for the same paint code.
Old 07-21-2010, 01:52 PM   #8
Take a look here
http://www.6speedonline.com/forums/996/217227-diy-color-match-bumperette.html
tawheed is offline   Reply With Quote
