Old 07-09-2010, 05:50 PM   #4
Originally Posted by chaudanova
Had the same problem a while ago... Most likely culprit is that your door lock microswitch (of of few) is toast... I'd suspect the microswitch that is in the door latch... That's the one that did the trick for me..
I took the mechanism apart and found cold solder joint between the printed wiring board and the connector. Reflow solder and it's back to normal. Mind you that my unit behaved erratically when the harness/connector was wiggled.
If you encounter similar situation, you may want to open the unit up and see. an hour of labor saved me $$$
here's a photo of the printed wiring board
sb01box is offline   Reply With Quote
