Old 01-26-2010, 05:48 AM   #1
jcb986's Avatar
Serpentine Belt Replacement
I just replaced my belt which was the most easiest and simpliest belt replacement that I have every made. Moved both seats all the way forward, removed carpet and engine cover panels, removed the engine cover to access the belt, used a 1/2" long breaker bar with 24MM socket. You push down on the belt tensioner to release belt tension and then slide it off. Just the reverse when you install the new one. Easy as putting down the top.
Old Hippie Young Heart
jcb986 is offline   Reply With Quote
Old 01-26-2010, 09:05 AM   #2
dallison's Avatar
yes it is. nice
dallison is offline   Reply With Quote
Old 01-26-2010, 09:39 AM   #3
I had a hard time getting the new belt on when I did it, maybe because it was cold?
The howtos I saw online showed people pulling it over the alternator pulley last. I ended up putting it onto the top idler last (between alt and the power st/ac pumps). I think the rounded edge of the idler helps a lot.
-james
'01 Boxster S, 51k miles
'05 Mazda 6 Grand Touring Wagon
yimmy149 is offline   Reply With Quote
Old 01-26-2010, 01:41 PM   #4
jcb986's Avatar
-james
I used my foot to push down on my breaker bar thus I was able to use both hands...yes, I had the top down.
Old 01-26-2010, 01:48 PM   #5
I routed mine this way :
Start on the passenger side of the engine and work your way around clockwise to the tensioner. Once you’ve wrapped the belt around that, untension the tensioner and slip the belt around the neighboring idler pulley.
http://ericfilcoff.com/pictures/986forum.jpg
2001 Boxster | 2007 Outback Sport
Need a freelance graphic designer?
Samson is offline   Reply With Quote
Old 01-27-2010, 05:23 AM   #6
jcb986's Avatar
There's probably 20 different ways to get it on, but which ever way, it is very easy. Crap, which the rest of the engine was just as easy to work on.
