Old 03-22-2008, 12:42 PM   #1
Allen K. Littlefield's Avatar
Question Removing hood crest?
Does the hood crest have screw off fasteners or are they pulled off? I tried to loosen it by using a flat nose pliers, it freed up a bit but did not release. Is there a mm size to the clamp/nuts as they look hexagonal? Any advice for removal?
AKL
Old 03-22-2008, 12:53 PM   #2
AKL
There's one or two 10mm nuts that hold it on. May take a little prying to get the gasket loose after that.
yellowboxster01 is offline   Reply With Quote
Old 03-22-2008, 03:45 PM   #3
Lil bastard's Avatar
They're just sheet metal nuts. Take care when tightening them - if you over-tighten them (easy to do), they'll 'strip' and you won't get them, or the badge, tight.
A 10mm nutdriver works well here because it's easier to tighten them w/o stripping. If using a socket and extension, don't use the ratchet handle, just turn the extension between your fingers - you'll have a much better feel for when they snug up.
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
Old 03-23-2008, 02:32 PM   #4
for the info. The 10mm nutdriver sounds like the best solution as I cannot get a socket up in the opening. Thanks again,
AKL
Old 03-12-2011, 01:07 PM   #5
Pat
Mine 2001 was an 8mm.
"Of all the extreme sports I've ever participated in- windsurfing, kite boarding, wake boarding, tow-in surfing and snowboarding- skiing, for me, made everything else easy."
-Chuck Patterson
Pat is offline   Reply With Quote
