Old 10-01-2007, 10:05 AM   #1
I had to play with my grounding too, but I can't remember where I grounded it... I think I added a ground going from the speaker wires to the antenna, in order to get rid of the whine, but as I said, my memory is hazy
Unfortunately, the whine is caused by improper grounding It's a vicious cycle.
No longer a Porsche owner.
http://www.whoistouching.us/porsche/...rthumbnail.jpg
Wonko The Sane is offline   Reply With Quote
Old 10-01-2007, 08:38 PM   #2
Found it
Well I figured out that when you group the ground wires all together like what is done on the stock radio you get a lot of feedback...That was another thing I found.. so I put each speaker + and - wire separate...
next thing is I found that the sirius connect box was causing the whine, so I removed that and took it back, i dont know if it was bad or not, but I am geting one that plugs into the front AUX port so I dont get the whining..
WHAT A ******************** to hook up a radio....Thanks for the ideas, boards like this are great...!
Dohertycm is offline   Reply With Quote
Old 10-01-2007, 08:57 PM   #3
boggtown
Guest
Posts: n/a
Good job. Thats why I spent 80 bucks to get mine installed. Plus I get lifetime warranty so if wires ever come loose I get it fixed for free.
Old 10-02-2007, 05:48 AM   #4
Jon - Yeah... If you've never installed a stereo before, the Box is one of the harder ones I didn't have too much trouble, but I've done a lot of stereo installs, so the troubleshooting process wasn't too bad for me. It can be a multi-day problem as it was here, if you're not completely familiar with installs like it, though
Dohertycm - Great! I'm glad to hear that you got it all sorted out
