Old 06-10-2007, 02:52 AM   #1
smoke?
I start my car and let it warm up for a few seconds. Back out my driveway and as I'm backing out I notice a cloud of smoke. Is this normal or is this something that should be immediately checked out? Instict says, don't drive it anymore and have it checked out but, I'm curious if anyone else has had the same problem?
thanks
yellowboxster01 is offline   Reply With Quote
Old 06-10-2007, 04:32 AM   #2
A little puff at startup is totally normal. If it's a lot of smoke, though, you've got problems. Don't sweat the smal stuff.
http://i19.photobucket.com/albums/b1...dingAvatar.jpg
Sold September 4th, 2007.
Rodger is offline   Reply With Quote
Old 06-10-2007, 08:16 AM   #3
Right, a little smoke at startup is not a bad thing. The flat design of the engine lends itself to oil pooling in the cylinder heads. Sometimes a little gets in and you get a little smoke.
If it happens later than right at startup, you might have other problems, like the AOS going bad. I'd check the throttle body area for oil. If there's oil drips around it, you may have a failing AOS.
2001 Boxster - Grey on Grey
1969 911T Targa - 'Stinky'
Old 10-07-2008, 02:23 PM   #4
Porschephile
Tomikaze's Avatar
What's AOS?
2004 Porsche Boxster S
Portland, Maine
Tomikaze is offline   Reply With Quote
Old 10-07-2008, 03:00 PM   #5
There Is No Substitute.
rick3000's Avatar
Air Oil Separator - http://mike.focke.googlepages.com/airoilseparatorreplacement
Old 10-07-2008, 04:49 PM   #6
I just did this a few weeks ago. That little puff of smoke will be more noticeable as you continue to drive it.
http://986forum.com/forums/showthread.php?t=18090
2008 Boxster S PDE2
cas951 is offline   Reply With Quote
