Old 04-19-2007, 05:37 PM   #1
boxsterz
Guest
Posts: n/a
dielectric grease
Anyone think this is a good idea when reconnecting plugs after disconnecting them?
Old 04-19-2007, 08:40 PM   #2
Hi,
Dielectric Grease typically had 2 functions in Car ignition systems. It provided a lubrication such as to a Distributor Shaft Cam and also to waterproof a connection such as a Spark Plug Boot.
While it certainly wouldn't hurt to use it, there wouldn't really be any benefit either.
With Coil-on-Plug, and the recessed Heads, there is already a watertight seal. And, again with the CoP, you don't need to lubricate it because you have a much larger surface to grip and separate the CoilPak from the Plug. Hope this helps...
Happy Motoring!... Jim'99
Old 04-20-2007, 12:41 AM   #3
boxsterz
Guest
Posts: n/a
How about connectors, especially critical electronics like DME, after disconnecting them?
Old 04-20-2007, 01:29 AM   #4
Hi,
Sure, you could. Again, I think it's unecessary really. You don't want that Grease attracting dirt/dust to the connector, so I wouldn't use very much...
