Old 04-16-2007, 03:55 PM   #1
How necessary is it
...to use an oil filter from Porsche?? Is there really that much of a difference between oil filters? I've got the MB1 0w40 already.
pompous is offline   Reply With Quote
Old 04-16-2007, 04:29 PM   #2
Considering its the only element that actually "filters" the oil, I would recommend using a quality brand. I believe the "factory" filters are made by Mahle.
2000 Boxster 2.7 (sold)
1978 911 SC (sold)
1970 914 w/2056 (sold)
racer_d is offline   Reply With Quote
Old 04-16-2007, 04:30 PM   #3
bmussatti
Guest
Posts: n/a
I believe quality does not cost more. That said, a Porsche oil filter can be bought for $12.04 and an air filter for $20.93. So how much are you going to save? Even if you saved 50% more...are you going to buy another mocha frappa no-whip decaf latte at Starbucks with your "savings"?
Old 04-16-2007, 05:37 PM   #4
This isn't so much a matter a starbucks coffee or a mcdonalds! I bought the car, I realize there are increased costs assosiated with owning it. The reason I ask the question is b/c I just found out I have alot of free time on Wednesday and would like to change my oil. HOWEVER the closest porsche dealership is about an hour away in Orlando. Therefore, I asked the question if a different brand...say purolator would be ok.
Old 04-16-2007, 05:46 PM   #5
Send a message via AIM to blinkwatt
Don't be cheap,just use your head on where you buy your parts from.
www.************************************************************
They can outprice Sunset on ALOT of maintainence parts.
-99' Zenith Blue 5-spd...didn't agree with a center divider on the freeway
-01' S Orient Red Metallic 6-spd...money pit...sold to buy a house
blinkwatt is offline   Reply With Quote
Old 04-16-2007, 05:50 PM   #6
You can make your own....
Tool Pants is offline   Reply With Quote
Old 04-16-2007, 05:59 PM   #7
Send a message via MSN to CJ_Boxster
I heard of hippies here in Long Beach using Toilet Paper in the 60's and 70's as an oil filter... Father remembers those days, he claims they worked but i would assume they would rip appart but toiletpaper wasnt as biodegradable as it is now.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
Old 04-16-2007, 06:47 PM   #8
The Porsche OEM filter element is not expensive, and equivalents are probably not available locally anyway. Pony up the $12something and live at peace knowing your Porsche has a good filter in it.
I should add, order one, or order a couple so you have one for your next change. No need to drive beaucoup miles to the dealer to get one!
2001 Boxster - Grey on Grey
1969 911T Targa - 'Stinky'
http://www.zoto.com/frayadjacent/img...f27a-4a399.jpg <---- my car. ^ crap I post.
"The existence of the flamethrower is evidence that someone, somewhere once said 'I want to set those people over there on fire, but I don't want to have to walk over there to do it.'"
FrayAdjacent is offline   Reply With Quote
Old 04-17-2007, 12:45 AM   #9
Hi,
Mahle and Wix make a compatible filter - both quality brands (Mahle makes the Porsche Filter). Wix makes the filters for NAPA, so I bet they'd have it...
Happy Motoring!... Jim'99
Old 04-17-2007, 05:40 AM   #10
Originally Posted by MNBoxster
Hi,
Perfect!!! That is exactly what i'm looking for. Just called and they got it in stock! Now I can get this done tomorrow. Thankyou!
Old 04-17-2007, 05:55 AM   #11
bmussatti
Guest
Posts: n/a
Pompous, make sure you get a new Crush Washer and Rubber Sealing Gasket with that NAPA filter.
Old 04-17-2007, 07:39 AM   #12
Hi,
While I agree with Bmus, you can usually get 2 cycles out of the Crush Washer by inverting it (have done it several times with my Esprit - Oil Change interval of 3k mi., never had an issue). The same is true of the Cannister 'O' Ring.
I don't actually endorse this practice, but in a pinch...
Old 04-17-2007, 07:29 PM   #13
Mahle is out. Hengst is in. http://www.renntech.org/forums/index.php?showtopic=9454&hl=unapproved
I have Wix in the car now.
All 3 come with the O-ring. None come with the drain plug washer.
I have reused the O-ring and washer several times, on my car. Also, I have not use a torque wrench on my car for an oil change in years.
My 1997 guinea pig still runs....
Old 04-17-2007, 08:08 PM   #14
I went ahead w/the oil change this evening. I took MNboxster's advice and went to NAPA to get the wix filter. I did change the o ring, but didn't really care so much about a drain plug crush washer either. I took out the plug and put it back in as tight as I have done any other car. I'll watch it to see if it starts leaking and go from there if it is. I was just glad to not have to order an oil filter and be able to change the oil myself w/some free time I had.
Old 04-17-2007, 09:42 PM   #15
Same here. The OEM porsche filters I've bought just come with the rubber o-ring and no crush washer. It is a mystery that some say the stock filter comes with a new crush washer because mine never have. My stock washer is on the 3rd oil change with no leaks.
'03 3.2L GuardsRed/Blk/Blk---6Spd
Options: Litronics, 18" Carrera lights, Bose sound, Painted to match roll bars.
http://i100.photobucket.com/albums/m...Mautocross.jpg
Adam is offline   Reply With Quote
Old 04-18-2007, 08:07 AM   #16
You can buy your oil filters online if your dealer is so far, 1 hour away. Try ******************************************************************************************** or ************************************************************. I think I bought Mahle the last time but for some reason, I had to cut off the edges of the soft cardboard/paper cover at the entrance of the inner hole to make it fit....it was weird...did anybody have that problem? I didn't want to force fit and break anything but the filter looks fine otherwise. I use a torque wrench but I don't think it's a big deal if you don't have one...just use your discretion.
porschedude is offline   Reply With Quote
Old 04-18-2007, 08:10 AM   #17
Thanks for those sites. I'm always looking for more options for parts. Just ordered plugs from pap-parts.com It seems like a pretty good place and yes, I stuck w/stock plugs lol
