Old 04-13-2007, 07:52 AM   #1
Porscheectomy
Originally Posted by AUDIOGUY
. My steering wheel was off center which they said they couldnt fix
This alone is enough to show that they're incompetent.
Did they give you an alignment spec sheet? Pulling after the alignment is inexcuseable.
Old 04-13-2007, 08:20 AM   #2
Hi,
Agreed! These cars use pretty flimsy suspension components (Alloy) compared to cars of yesteryear, primarily to save weight and increase Range.
Most people don't realize that there is no Service Interval on an alignment. Hit a Pothole, SpeedBump or even a Parking Curb on the way home from the Alignment Shop and you can throw the whole thing off again.
It is an As Needed item which should at least be checked Annually. This will insure that you're getting maximum wear from your Tires and that the car is properly controllable and a Pleasure to drive.
You should always get a printout from any Alignment and save them. This allows you to track any wear over time to the suspension components...
Happy Motoring!... Jim'99
Old 04-13-2007, 10:37 AM   #3
darned right. i check mine three times a year and usually wind up setting it twice. potholes, etc. in atlanta are horrible. poor alignment will kill your tires, gas mileage, and handling (especially in the rain).
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
Old 04-13-2007, 04:45 PM   #4
I did get a print out from the last alignment. It said the toe was in spec as was the rest of the front end. The lt rear camber was slightly out but not a worry. The spoke of the wheel was off... I was going to bring it back but decided to wait and get it redone elsewhere. It is very easy to set the toe on a car and manipulate the heads on the alignment machine to get a good print out.
Good to go now!
Joe DiMonte
2001 Boxster S
Triple Black
AUDIOGUY is offline   Reply With Quote
