04-10-2007, 04:53 PM
Oddments Tray Cover
The hinge on my oddments tray cover broke this afternoon. It's difficult to believe that this part was made so poorly.
I found the service bulletin for replacing it on a 996, and it appears that the same procedure applies to the 986. Has anyone had experience replacing the hinge themselves? Anything to look out for?
04-10-2007, 07:34 PM
I had replaced mine, parts are cheap and install took about 20 minutes, only tool you need is a rivet gun and a little sandpaper if I remember right.
04-11-2007, 04:48 AM
I replaced mine last week and it took 20 minutes. Very easy and Travis is right in terms of the rivet gun and sandpaper but you will need a drill also. The parts were approx $20.
Bill
04-13-2007, 10:29 AM
Thanks - your responses are encouraging. I'm planning to order the part from Suncoast today. With luck I'll be able to do my install next weekend.
04-28-2007, 10:58 AM
If anyone else ever has this problem it is indeed an easy fix. Some instructions I found make it apper that you have to remove the center cosole, but that is not necessary. You will need a rivet gun, torx driver, handsaw and drill.
If anyone in Central Virginia ever needs a hand with one, let me know.
04-28-2007, 11:10 AM
kevin, I ordered repair kit yesterday from Sunset Porsche it cost me $17.00 plus $6.00 shipping and they had it in stock.... Lee
04-28-2007, 03:32 PM
me too....I need to place an order.
00 Boxster Tip Blk/Blk
100% de-ambered
painted center console
painted bumperettes
autoband paint protection
wheel caps & colored crests
door sills
Valentine One
