Old 03-25-2007, 07:26 AM   #1
Looking for Key Switched Fuse
Correct, it's an 06 and the detector is not a V1 and does not have the 4w RJ-11 connector. I simply need to connect 1 hot wire to a key switched fuse. The other wire will go to ground. Trust me, I know how to do this if I can just find the switched fuse to tap into. Most of the fuses I check with my voltmeter have 12V on them even though the key is off. Today I'll make sure they are not just hot to the 3-5 minute period before everything shuts down. I think things like the power windows etc still for for a short period of time, maybe I was testing too soon?
06 Boxster
Seal Grey
Bose, Xenons, 17"
http://img144.imageshack.us/img144/8...rivewayic1.jpg
tomk17 is offline   Reply With Quote
Old 03-25-2007, 08:54 AM   #2
FOUND! Switched 12V on Row D Fuse Slot #4
Fuse box Row D, Fuse #4 is empty on my 987 and will provide 12V only when switched on by the key. This is a blank in the little book so I imagine that regardless of the options on your car, this looks to always be a spare empty port.
06 Boxster
Seal Grey
Bose, Xenons, 17"
