Old 03-25-2007, 07:21 PM   #41
Brucelee's Avatar
Originally Posted by Adam
The rev limiter is only in affect when accelerating. If you down shifted into a lower gear going into a curve then that's called a mechanical over-rev if it went past redline. Usually the back tires lock up momentarily and you get jerked forward pretty hard soon followed by some expletives...ask me how I know It can potentially kill your engine.
Indeed. When you mis a down shift, there is precious little the car can do to save you.
Rich Belloff
Old 03-25-2007, 07:26 PM   #42
Originally Posted by RandallNeighbour
Jim, thanks for that good long explanation. I always learn a lot from you when you are in education mode
One follow up question. How often or when should I be adding an additive, or will running Chevron with Techron consistently keep the carbon deposits low?
Hi,
I add a Can of Jectron at the start of the season, in addition to working on engine deposits, it cleans the Injectors and Valves - the $10 Tune-Up '). Using good Gas and not storing it for extended period will usually be all you need to a year-round car...
Happy Motoring!... Jim'99
Old 03-26-2007, 10:50 AM   #43
Jim...
I thought I read somewhere on here that the injector cleaners may leave some stuff in the oil. Would it be better to run the cleaner 3000 miles prior to the next oil change? That way that stuff won't stay in the oil all year round?
Just wondering, since I have some techron I'd like to run in mine sometime. Just deciding when to use...
Georg
2003 Boxster Seal Gray/Gray
TIP
5000 miles (for some reason I'm proud of this)
porschegeorg is offline   Reply With Quote
Old 03-26-2007, 11:09 AM   #44
Originally Posted by porschegeorg
Jim...
Georg
Hi,
It is better to do this prior to an Oil Change, but in the case of the Jectron, not absolutely necessary. Any Jectron which get into the Oil will Flash off. So far as Techron, I cannot say. Check their MSDS sheet and look at the volatility statistics, that should tell you...
