05-20-2007, 07:50 AM
#36
Originally Posted by rick3000
I didn't want to start a new post so here are some more questions I have.
Is it normal to hear the soft top shifting while it is up when you drive over a bump?
Yes, you'll hear some creaks and groans sometimes, but it shouldn't be too bad. With a car like the Boxster, the body will flex a bit and the top will move a bit as a result.
Do the porsche OEM dash cup holders work well or is the ultimate cupholder better?
The OEM dash cup holders SUCK. Well, for anything larger than a 12oz can, they suck. I bought one of the Ultimate Cupholders, and love it. I highly recommend.
How hard is it to move the a/c to the lowest console position?
Not too hard, you just need to get the correct bezel for it, and run the cables down there. Which actually might be a little tricky. I did the reverse, moved the climate control to the top, and getting the cable back up there was a little tricky.
Is it normal to have the upper dash the hangs over the lower dash (above the shifter boot) not perfectly centered?
Not sure, but I think it should be. If the bottom dash piece is not straight, it might have been removed and not properly reinstalled.
(123456789)
2001 Boxster - Grey on Grey
1969 911T Targa - 'Stinky'
http://www.zoto.com/frayadjacent/img...f27a-4a399.jpg <---- my car. ^ crap I post.
"The existence of the flamethrower is evidence that someone, somewhere once said 'I want to set those people over there on fire, but I don't want to have to walk over there to do it.'"
