Old 05-09-2007, 09:18 AM   #2
spark00
i believe security clips are on lower part of the radio and they seem to be spring loaded. instead of using the tool, i took the assembly out and used screw driver from the back. if you have the tool, i would think you insert them through top portion of the radio on each side all the way in, lower them to push the security clips in then pull the radio out by pulling the radio face plate. i don't think you have to worry too much about breaking anything though.
spark00 is offline   Reply With Quote
