Thread: Spark plugs
Old 04-25-2007, 04:20 AM   #20
John V
Originally Posted by MNBoxster
Hi,
Interesting observation. Did you use normal Anti-Seize or Hi-Temp Anti-Seize?
OEM Plugs are Resistor Plugs designed to reduce Radio Interference. A Normal Anti-Seize would tend to work as an Insulator while a Hi-Temp (with it's high metallic content) would work as a Conductor, either could interfere with this property of the Plugs...
Happy Motoring!... Jim'99
I cannot think of way that high-temp anti-seize between the plug's common terminal and the engine could interfere with the series resistance of the spark plugs. Can you please educate me?
John V is offline   Reply With Quote
