Old 04-13-2007, 09:57 PM   #2
MNBoxster
Originally Posted by bmwm750
I have no problem with the inserts....I used some rubber padding between the tabs and the rollbars and used black zip ties to keep them tight so they dont rattle....however... the center section rattles and it drives me nuts! Anyone have a permanent fix for this?
Patrick
Hi,
If you searched the archives, you'd see there are a number of fixes. I used double-sided Foam Tape which not only insulates the pieces from vibrating, but also wedges them into place. Others have used reportedly equally effective methods - cruise the archives and discover...
Happy Motoring!... Jim'99
