Speedster humps
Even factory humps, if not adjusted and installed properly, will cause a problem with the windows and opening/closing the doors. The mounting hardware on the humps is adjustable and should be adjusted as required for each installation to compensate for alignments of the clamshell to which the speedster humps will be fitted to. A minor missalignment of the clamshell will impact the alignment of the speedster humps. An as a result it will affect the operation of the windows and/or opening/closing of the doors with the windows raised.
John
