Originally Posted by blinkwatt
When I replaced them I used a screw type clamp to connect the bellow on the seperator to the engine,it might have loosened causing the air leak. I will check it out more tommorow as I have the day off.
Well it is 1:35AM and I was full of energy after I got off work at mignight so I set up a bunch of lights under the car,checked the bellow connection and low and behold,the screw clamp was loose and the bellow wasn't properly seated all the way. There was some oil residue around where it connects so I cleaned it up,now I can tell if it leaks again because if it leaks it won't be clean anymore. Now time to take it for a spin and see if I can agrivate it. I'm confident though I found the cause!
-99' Zenith Blue 5-spd...didn't agree with a center divider on the freeway
-01' S Orient Red Metallic 6-spd...money pit...sold to buy a house
