Old 12-14-2006, 12:11 AM   #6
blinkwatt
Send a message via AIM to blinkwatt
My old oil seperator had 55k on it and I suspect it had had some small leak for a long time,everything around it where the "J" tube connects to the actual oil seperator had a light oil mist to it. I replaced both the oil seperator and "J" tube. When I replaced them I used a screw type clamp to connect the bellow on the seperator to the engine,it might have loosened causing the air leak. I will check it out more tommorow as I have the day off.
-99' Zenith Blue 5-spd...didn't agree with a center divider on the freeway
-01' S Orient Red Metallic 6-spd...money pit...sold to buy a house
blinkwatt is offline   Reply With Quote
