Old 05-16-2026, 01:50 PM   #2
JFP in PA
The most common fault causing P2096 are small exhaust system leaks. If the car were in my shop, I would smoke test that bank's exhaust system for very small leaks.
I know you commented that you had the system tested, I would test it again, very carefully and with the system disconnected and plugged as the leaks can be incredibly small.
