Old 02-20-2026, 05:34 PM   #1
headdead
Engine swap: 2005 997s auto into 2001 986s manual
My 2001 Boxster S needs new variocams and other parts. At over 100k miles I don't want to put $3k in variocams, plus a ton of work pulling the head covers to replace them.
Instead, I have a line on a
2005 987s w/ 41K miles, auto trans. ENTIRE vehicle (front end collision) for 5K. I figure I could use the engine and sell the tiptronic, convertible top, decklid, fender, rear bumper cover, wheels, etc. I could also scavenge some suspension and other parts (coolant tank.) for my 2001.
Questions I need to answer:
- If I replace the 986s 3.2 engine with the the 2005 987s 3.2 engine, would I use the 987 engine wire harness, DME, ECU, immobilizer and anything else I scavenge? Will I need to re-pin the 2001 body wire harness at all, in order for it to go into the 987 DME, or can I easily use all the 2005 harnesses (harnessii?) I believe my 2001 has canbus of some sort.
- What mods will I need to make to reuse my manual trans (and clutch and flywheel) if the donor engine and associated parts are from a tiptronic? Are the engine wire harnesses different between the different transmissions?
- I believe I may need to use the 987 fuel pump and ABS module but that seems pretty simple.
- Without a hoist I managed to drop my 2001 engine and trans 2 years ago to replace the plastic chain rails and replace the IMS. This time I can rent a DIY shop with hoist near me.
In my mind having the entire 987 makes this project much more DIY friendly. What am I missing?
headdead is offline   Reply With Quote
