Old 06-22-2025, 06:56 AM   #1
JFP in PA
Both the coolant tank and the AOS are a bit of fun on a 911 variant. There is no real access thru the rear bulkhead, everything needs to be done either from under the engine cover or beneath the car. Yes, you will need to lower the engine a bit to do the coolant tank, it also makes the AOS a bit easier as well.
Don't overthink the process, your Quick jack and lift table should work fine. Work methodically and double check everything is back and tight before you put it back up.
