Old 01-06-2025, 04:18 PM   #3
elav
Here is the arm for the convertible top transmission
I'm pointing to the rubber piece that can be broken or missing and cause a rattle
If you look at the top of that piece you circled in your picture there should be a cover. If you remove that cover you should see the plug for the rear defrost. It might have broken off and is rattling around in there.
'98 Boxster 986
'87 911 Carrera Cabriolet
elav is offline   Reply With Quote
