Old 12-14-2024, 05:44 PM   #1
djw8282
djw8282's Avatar
First:
check make sure your fuel pump relay and your fuel injector relays are good.
Test them or simply replace them.
That way we know for sure they are not the fault..
The little contact points in them can corrode over time.
Then.....
Spray the starting fluid where the tubing detaches at the throttle body.
Open the throttle body butter fly if you can when you spray the fluid.
So you understand why I am having you do this.
Opening the butter fly gives the starting fluid a better chance of getting into the cylinders when you crank it over.
If the engine fires at all using starting fluid that will tell me that you most likely have a fuel delivery issue...thus it will not fire or start under normal conditions.
If it will not fire using starting fluid then the issue is most likely an electrical (spark issue).
So the results from the use of using starting fluid gives us a direction to proceed with your diagnosis of the no start issue.
Post here what you find from this test.... I will try to help you out if I can
Questions....
You say you have an after market high flow intake.
what changes did you make to the stock intake????
What type of air filter are you using????
Is it dry type or is it an oil on the filter type like a K&N????
Any other Mods to the engine???
What year is the car????
Hey blue62,
I know it's been a long time. I replaced the battery, fuel pump relay, and ignition relay which didn't fix it.
I just tried the starting fluid and it kicked on for a second then shut it down. I put some fresh gas and nothing. I did hear a stretch from the starter. Any suggestions?
djw8282 is offline   Reply With Quote
