Old 08-28-2024, 09:26 PM   #4
Hamstuh
Originally Posted by lurky View Post
Thanks for the reply!! the engine light is not blinking so im trying to get the code, I got my hands on a Intey OBD (ny-om329) auto reader. Do you happen to know if this will work on a 2007 boxster? IT appears to be pretty old.
I have personally not used that one before however so long as it functions as a proper OBD scanner it should be fine. there are instances where codes can be Porsche specific, though generally dont cause any issues unless you want to do certain things other than scanning itself. ive used all types of scanners on mine from snapon to cheap amazon ones too without any issues. Just verify it has the proper OBD connection type (most are the same anyway) and verify the scanner itself works.
Hamstuh is online now   Reply With Quote
