Old 05-21-2024, 10:47 AM   #1
78F350
Motorist & Coffee Drinker
78F350's Avatar
It definitely sounds like a problem with the window regulator. Most likely the cable has come off one of the rollers and jammed. It should be obvious to see with the interior door panel removed. If the cable and rollers look good, then I'd try power directly to the motor.
