Old 02-22-2024, 03:44 PM   #2
alexc0814
Originally Posted by Burg Boxster View Post
sounds like the old Boxster "little red clip" would solve your problems similarly and allow windows to dip slightly when top is being raised / lowered.
Two reasons (among many I'm sure) most cabs dip windows is to:
  1. prevent any undo pressure on windows while top opens/closes
  2. ensure windows seat properly into top seal/channel once closed
Shouldn't be issues w you manually raising/lowering but suggest you still dip thwindows a few inches before opening or closing..
Regardless, glad you were able to resolve issue - nice job
Seems like something went wrong, or something super coincidental happened.
When I latched my top in (for the second or third time without a relay) my central locking system light went red and the horn double beeped, along with the passenger side window not dropping when the door opens.
I had this exact issue last year but replacing the passenger door lock fixed it. I put the top relay back in after but nothing changed unfortunately. I think this may be coincidental since today was the first very warm day, which is when the issue was most prevalent last year on my old door lock too. The issue is accompanied with a double beep on unlock.
alexc0814 is offline   Reply With Quote
