12-26-2023, 03:18 PM
#1
Motorist & Coffee Drinker
...if purchase a salvage package... immobilizer, ECU, ignition unit, door lock chamber, and keys... all matching - will this work?
Yes, with a few caveats: - It must be from a similar model car. The model years break down to:
1997 - 1999 Cable throttle.
2000 - 2002 Electronic throttle.
2003 - 2004 Electronic throttle with 'Variocam plus' 3 chain engines. More use of CAN bus.
- It will function, but will not be correctly programmed to the specific VIN and options of the car. May cause problems for future dealership type maintenance on the car.
- The minimum you need to get the car running is a matching DME, Central Locking Module (immobilizer box under the seat), and Transponder from the key fob. The other parts are optional.
