Thread: Seat Switch
Old 09-21-2023, 11:00 AM   #3
Rick_22
Thanks for the info.! The other problem that I have is that the seat is in the lowest position, so removing the cover is going to require me to remove the two white plastic latches under the seat to be able to lift the bottom of the seat up high enough to remove the screws on the seat cover. I assume the you have to remove the cover to be able to remove the lever? I also assume that if I am missing any springs or any other parts that my only options are to replace the switch or find a non working switch for parts? I don’t see where Porsche sells anything but a new switch.
Rick_22 is offline   Reply With Quote
