Old 08-31-2023, 08:31 PM   #1
imtylre
What is this cable in the door?
I have been trouble shooting my boxsters passenger side door not dropping when the handle is pulled. I already replaced the regulator because it was going bad (screeching noise), and the microswitch in the doorhandle. And then today I was fiddling in the door and touched this wire and movement... The window moved! Pushing up and down on this wire seems to fix a connection and let the door assembly know the door is open, and the window drops.
Above is the indicated wire I have been fiddling with.
Does anyone know what the part number is? I've been going through part catalogs and diagrams and can't seem to find it. Might need to replace this, or what it's connected to.
imtylre is offline   Reply With Quote
