Old 08-24-2023, 10:08 AM   #1
A8ked
A8ked's Avatar
My hardtop used to leak slightly at the top front corner on the drivers side. a couple years ago I installed a new window regulator and while I had things apart I adjusted the window height and angle following the instructions on the Pelican site. The leak is gone in rainy conditions, but still drips slightly when under pressure from a car wash. The Pelican instructions say you should not be able to pull a piece of paper thru the seal when the window is up.
1998 Boxster
1991 Carrera
A8ked is offline   Reply With Quote
