Old 08-07-2023, 07:53 PM   #1
78F350
Motorist & Coffee Drinker
78F350's Avatar
Your VIN identifies it as a 1997 model. They do have a different style oil cooler.
Are you installing an oil cooler for a 1997? Be sure to specify the model year when you search.
That's the only year with that style.
If you are installing a later model oil cooler on your '97 you need an adapter plate like this:
Oil Cooler Adapter for '97
This is the adapter to put a later model or S model oil cooler on a 1997 engine. List price is now about $190 new.
Associated Part Numbers: 996 107 129 00, 996-107-129-00, 996-107-129-00-OEM, 996.107.129.00, 99610712900
"Porsche Heat Exchanger Mount Plate"
'Gently used' and fully functional. Comes with 4 New o-rings to install the adapter.
Your new oil cooler will need 4 more o-rings. Pretty sure the part numbers are 99970740940 (26 x 3mm) & 99970738940 (35 x 4mm), but I am occasionally wrong.
$75 shipped. USA addresses only.
