Old 07-21-2023, 10:33 AM   #2
elav
Does the key work in the center console lock? If not, then the ignition was probably changed. If it works in the center console, I would put that in the door.
The fob either isn’t programmed to the car (and without the programming code can’t be) or has gone thru the wash and doesn’t function other than lighting the led (this is the case with mine).
elav is online now   Reply With Quote
