Old 07-17-2023, 11:57 AM   #1
JFP in PA
Originally Posted by nuvolari View Post
Oh, JFP, one question I have is if it is possible to tell anything by how much the pistons rock in the cylinders? How much is normal and can you even tell how much is not? They don't rock excessively but they do move when pushing on them. Is there a method to test them? Should they be at TDC or BDC or can nothing even be determined by any of this?
Thanks as always for your help....
No, because there is no spec for how much they should move, plus these cylinder liners tend to go oval with wear. The proper way to measure piston to bore clearance is to use a bore gauge to measure the bore at the thrust sides and use a micrometer to measure the piston skirt diameter, subtract one from the other.
