Thread: Coolant leak
Old 07-09-2023, 07:18 PM   #10
78F350
Motorist & Coffee Drinker
78F350's Avatar
The way I see it is two types of fluid can come out that drain from the HVAC; water from condensation with the AC running or coolant from the heater core leaking.
If it is not leaking from the HVAC drain, in the front of the car, there are three types of coolant lines.
  • Big -main coolant to and from the radiators.
  • Medium -heater hoses.
  • Small -radiator bleed lines attached to the top corner of each radiator.
That's all else there is.
