Did this couole of months ago.
First you place the engine to TDC and time the Bank 1 cams. Then rotate the engine 360 degrees and lock it agian to TDC and time the Bank 2 cams.
Then test with hand tool from crank that engine rotates freely and only to the normal rotating direction (clockwise).
I had same dilemma from the factory manual and took several times reading it to be certain how to get this done right...
2001 996 C2 Manual
