Old 04-07-2023, 06:17 PM   #11
JFP in PA
Originally Posted by Kice View Post
Thanks. I checked the relays in the trunk per Bentley manual and they all seem ok.
I also measured the voltage directly from the CPS connector when cranking the engine and it clearly produces a signal. So the CPS seems to be fine.
I am however unclear how to check if that signal reaches the DM, because when I disconnect the DME connector to check for the signal on the respective pins the car will not start at all. I guess need to jumper the starter for that test?
No, the CPS is a Hall Effect sensor, it only has to turn over to generate a signal, it does not need to run.
