Old 04-05-2023, 11:45 AM   #1
JFP in PA
Originally Posted by Kice View Post
Thanks for the quick feedback!
CPS: Though it's brand new (Pelican) and no sign of not working (tests alright), I will get another new one to be absolutely sure it's not that.
Immobilizer: Car was in garage for past 3 years so can exclude that it got wet. Also: would the immobilizer not prevent the engine from cranking in the first place?
Will check the relays in the back.
Long before aimlessly throwing parts at it, why not check and see if the DME is getting a signal from the CPS? Trace the CPS wires to the connector at the DME and look for a low voltage signal on them at the DME end when the engine is turning over; if you have a signal, it isn't the CPS.
