Old 09-22-2022, 08:57 AM   #1
JFP in PA
In order for the car to start, the DME has to see a signal from the crank position sensor telling the DME that the engine is rotating, it then turns on power to both the ignition and fuel pump. If the DME does not see that mV signal from the CPS, the fuel pump will not get power, and the car will not run.
