Thread: ABS Light
Old 09-03-2022, 10:03 AM   #3
JFP in PA
Originally Posted by DrRobin View Post
My Autel code scanner found the error as
4210 - Speed-sensor wire, rear right
I am guessing that is either a bad connection or the sensor is failing? I have read that a good sensor reads about 1.8kOhm.
I don’t know if you can point me towards a guide for stripping the sensor out?
The ABS light didn’t stay on this morning.
Robin
Hope it is a wiring issue as the speed sensor itself is imbedded in the hub bearing and requires replacing that bearing. Along with a resistance spec, the sensor in question should generate an AC millivolt signal when the wheel is spun.
