Old 08-04-2022, 06:45 AM   #1
JFP in PA
Originally Posted by Most_Wanted View Post
My oil cooler went bad and my mechanic is trying to find the correct parts. The diagram he is referencing shows a "plate" that is sandwiched between the engine and oil cooler. My engine did not have the plate nor do the other 986 engine I've researched on youtube/google images. Can someone with more experience confirm that there is no "plate" to begin with & also on the correct size seals.
2000 Boxster S
Engine 3.2
Seal sizes my parts guy showed me.
28x2.5 mm
35x4 mm
26x3 mm
I don't know why there is 3 different sizes. The oil cooler should only have 2 different sizes correct?
He is going off old data; only the very early 2.5L engines used an adapter plate between the cooler and the block, your engine does not. There are only two size O-rings required, two of each size. Any dealer worth their salt can get you set up quickly.
