Old 06-27-2022, 05:58 PM   #1
bg305
01 Seal Gray 986 S
bg305's Avatar
Make sure your oil is not overfilled as well. While replacing the AOS did solve this for me, I remember reading that due to the flat engine overfilling can put you in a situation were the oil sits against the rings and seeps through. The dash oil level indicator has a full line that is below the final bar. Make sure you are not above that fill line.
Something to check that is an easy fix.
bg305 is offline   Reply With Quote
