Old 05-25-2022, 01:56 PM   #11
JFP in PA
Originally Posted by suburban99 View Post
Porsche AOS installed including new J-tube and the lower AOS hose plastic tube piece..
A real PIA to change the lower hose/tube. It is Threaded thru the legs of the intake manifold...Airbox/ intake manifolds/throttle body etc all needed to be removed.
AOS is not to bad to change.
So far good! No smoke at all. Hopefully that's the ticket! Thanks for all the input.
Next oil change, lower your oil level two bars below the full mark (around 1/2L), which will help even more.
