Thread: Headlight dim
Old 04-30-2022, 07:18 PM   #1
dghii
Check the headlight grounds. The wiring on these headlights is marginal at best.
+1. The insulation on the wiring inside the headlight assemblies just falls apart with age. You may have an (almost) short inside the assembly. Pull out the assembly and take a close look inside. Liquid electrical tape works pretty good to re-insulate the wires if you don't feel like pulling it all apart.
