Old 04-03-2022, 06:50 PM   #1
ike84
Adding fuel pressure sensor
Sorry for all the posts...
I want to add a fuel pressure switch for a custom warning system. The easiest place seems like the test port on the bank 1 rail. However, from what I have been able to find it is a screwy thread size which would require an adapter to a schrader valve (since that's what most of the diagnostic gauges use) and then another adapter from a schrader valve to 1/8 npt (which is what most switches use).
That seems sloppy, and a lot of joints that may leak.
Any suggestions?
Sent from my SM-G970U1 using Tapatalk
