Yeah, your offsets should help your fitment and looks like you should be fine. The AR-1s have a pretty wide section width so that would also help your fitment based on the tires you're considering. I have a pretty aggressive alignment with 2.6deg Front (GT3 LCAs)and 2.4deg Rear negative camber. That's likely a wash versus your lowering springs.
On the front I did have a touch of rubbing with the wheel liner, but the liners tend to deform over time and can be re-molded with a heat gun.
From this pic you can get an idea as to how tight the rear was.
2022 PCA Zone 7 Autocross Chair
2001 Boxster 986 (base) #414
-PCA GGR: Class Champion AX12 '18, '19, '20; CC06 '21; CC05 '22; PAX 5th '19, 3rd '20, '21, & '22
-PCA Zone 7: Class Champion P14 '18, '19; P02 '20; P-03 '22; PAX Champion '20 & '21
